-17%
249 € 299 €
Décodage VIN
Décodage VIN Empty Décodage VIN
Message par Sebcorvette76 Mar 7 Avr 2015 - 17:29
Salut les gars qui peu me décodé ce VIN?
1G1YY24U255104724
Merci d'avance..
Sebcorvette76
Sebcorvette76
Masculin Nombre de messages : 1823
Modele Vette : Corvette C7 cabriolet Bleue 2015 et Ford F100 1977
Décodage VIN Empty Re: Décodage VIN
Message par Sebcorvette76 Mar 7 Avr 2015 - 17:34
J'ai celui la aussi
1G1YY26WX85106904
Sebcorvette76
Sebcorvette76
Message par Yann Mar 7 Avr 2015 - 18:13
Date de fab 4 oct 2004
VIN: 1G1YY24U255104724
VIN Decode
1:U.S. BUILT
G:GENERAL MOTORS, GENASYS L.C.
1:CHEVROLET
YY:CORVETTE
2:TWO-DOOR (07,08,77,87)
4:ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINT SYSTEM (FRONTAL & SIDE)
U:ENG OPT - LS2 DISP - 6.0L CYL - V8 FUEL SYS - SFI DIV - 1,2 PROD IN - U.S.
2:CHECK DIGIT
5:2005 MODEL YEAR
5:BOWLING GREEN KY
104724: PRODUCTION SEQUENCE
RPO Codes
19U = PRIMARY COLOR EXTERIOR, LUXO BLUE MET (19U)
1SA = PACKAGE-OPTION 01 (1SA)
313 = TRIM COMBINATION LEATHER, LT CASHMERE (3) (04) LEATHER TRIM(313)
31I = INTERIOR TRIM LT CASHMERE (04) (31I)
AAB = MEMORY DRIVER CONVENIENCE PACKAGE DRIVER MEMORY CONVENIENCE PKG
(AAB)
AG2 = ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR
(AG2)
AJ7 = RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT & SIDE
INFL RST FRT & SI(AJ7)
AQ9 = SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AU8 = LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY REMOTE ENTRY LK CONT
(AU8)
AX4 = RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) FRT & RR MAN RST
SYS FOR EUROPEAN VEHICLE(AX4)
B4H
BAG = PARTS PKG EXPORT PARTS PKG(BAG)
BGR
CE4 = WASHER,HEADLAMP,HIGH PRESSURE HDLP WA(CE4)
CF7 = ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7)
CJ2 = HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT
AUTO/AUX CONT(CJ2)
CT1 = COUNTRY,BELGIUM(EXPORT) BELGIUM(CT1)
D42 = COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
DD0 = MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DD8 = MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT
SENSITIVE(DD8)
E2C
EXP = EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP)
FE3 = SUSPENSION SYSTEM,SPORT SPORT SUSP(FE3)
GU6 = AXLE,REAR,3.42 RATIO 3.42R(GU6)
IL3 = TRIM,INTERIOR DESIGN INTERIOR TRIM DESIGN(IL3)
J55 = BRAKE SYSTEM,HEAVY DUTY POWER HVY DUTY PWR BRK(J55)
K63 = GENERATOR 110 AMP 110 AMP GEN(K63)
KA1 = HEATER - SEAT ST HTR(KA1)
KNP = COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
KNR = COOLING SYSTEM AXLE AXLE COOLING SYSTEM(KNR)
KPS = OIL COOLER,ENGINE ENG OIL COOLER(KPS)
LS2 = ENGINE,6.0L(364CID) GAS V8 6.0-H(LS2)
MAE = MARKETING AREA EUROPE(EXPORT) EUROPE(MAE)
MN6 = TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD
M/TRANS PROVISIONS(MN6)
MZ6 = TRANSMISSION MAN 6 SPD, TREMEC, 85MM, 2.97 1ST, 0.71 5TH 0.57 6TH, O/D 6-SPD
M/TRANS(MZ6)
NK4 = STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
NP7 = STEERING COLUMN(EXPORT) STRG COL(NP7)
NT4 = EMISSION SYSTEM EEC 05 EEC 05 EMIS(NT4)
QG6 = WHEEL 18 X 8.5 FRT & 19 X 10 RR, ALUMINUM, STYLED ALUM WHL(QG6)
T62 = LIGHTING DAYTIME RUNNING ----DELETE T62)
T79 = LAMPS,REAR FOG RR FOG LP(T79)
T84 = HEADLAMPS,RH RULE OF THE ROAD,(MARKED E) RH RULE OF ROAD HDLP(T84)
T90 = LAMP,SIGNALING AND MARKER(EXPORT) SIGNAL & MARKER LAMP(T90)
T93 = LAMP,TAIL AND STOP(SPECIAL) SPECIAL TAIL & S/LP(T93)
U19 = SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR KPH SPEEDO(U19)
U3U = RADIO AM/FM STEREO, SEEK/SCAN, DVD, CD, CLOCK ETR, NAVIGATION, VOICE REC,
MP3 RADIO,DVD,CD,CLK,NAV,VOICE RECOGNITION(U3U)
U52 = CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
U65 = SPEAKER SYSTEM 7,PREMIUM 7 SPKR SYSTEM,PREMIUM(U65)
UA2 = THEFT DETERENT SYS EXPORT SPECIFIC EXPORT SPECIFIC THEFT DETERENT SYSTEM
(UA2)
UH3 = INDICATOR LOW TIRE PRESS, VAR 2 LOW TIRE PRESS IND(UH3)
UL2 = RADIO FREQUENCY(EUROPEAN) EUROPEAN RDO FREQ(UL2)
US3 = ANTENNA DIVERSITY DIVERSITY ANTENNA(US3)
UV6 = DISPLAY,HEADUP HEAD UP DISPLAY(UV6)
V76 = HOOK,FRONT TOW(EXPORT) FRT TOW HOOK(V76)
V78 = VEHICLE STATEMENT(DELETE)(EXPORT) V78)VEHICLE STATEMENT-DELETE
VC5 = LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL
USED OUTSIDE U.S. AND JAPAN(VC5)
VG1 = PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED,
CLEAR,EXPORT CLEAR UNDERHOOD CORROSION PREVENTIVE(VG1)
VG9 = PROTECTOR WAX,EXT BODY(EXPORT) PROTECTIVE BODY WAX(VG9)
VH5 = PLATE,VEHICLE IDENTIFICATION(EXPORT) VEH ID PLT(VH5)
VJ4 = LABEL, EXPORT CHILD SEAT LOCATION LABEL CHILD SEAT LOCATION(VJ4)(EXPORT)
VL4 = LICENSE PLATE,FRONT MOUNTING PACKAGE EEC FRT LIC PLT MTG PKG FOR EEC(VL4)
XGN = TIRE FRONT P245/40ZR18-88Y BW HW4 (EMT) HI-PERFORMANCE TIRE(XGN)
YGJ = TIRE REAR P285/35ZR19-90Y BW HW4 (EMT) HI-PERFORMANCE TIRE(YGJ)
Z51 = PERFORMANCE HANDLING PACKAGE PERF HDLG PKG(Z51)
Fab 7 sept 2007
VIN: 1G1YY26WX85106904
VIN Decode
1:U.S. BUILT
1:CHEVROLET
YY:CORVETTE
6:ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINT - FRONT, SIDE, & OCCUPANT SENSOR (AJ7 W/SENSOR)
W:ENG OPT - LS3 DISP - 6.2L CYL - V8 FUEL SYS - SFI DIV - 1 PROD IN - U.S.
X:CHECK DIGIT
8:2008 MODEL YEAR
5:ANTWERP BELGIUM
5:BOWLING GREEN KY
106904: PRODUCTION SEQUENCE
RPO Codes
193 = TRIM COMBINATION,BLACK/EBONY LEATHER LEATHER TRIM(193)
19I = INTERIOR TRIM COLOR BLACK/EBONY INTERIOR TRIM(19I)
89U = EXTERIOR COLOR,PRIMARY EXT COLOR(89U)
AAB = MEMORY DRIVER CONVENIENCE PACKAGE DRIVER MEMORY CONVENIENCE PKG(AAB)
AG2 = ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
AJ7 = RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT & SIDE INFL RST FRT & SI(AJ7)
AL0 = SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE
DETECTOR INFL REST IND SENSOR(AL0)
AU8 = LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY REMOTE ENTRY LK CONT(AU8)
AX4 = RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) FRT & RR MAN RST SYS FOR EUROPEAN
VEHICLE(AX4)
B4H
BGR
BS1 = INSULATION,ACOUSTICAL ACOUSTICAL INSULATION PKG(BS1)
CC3 = ROOF,SUN,REMOVEABLE PANELS(TRANSPARENT PLASTIC) CLEAR ROOF PANEL(CC3)
CJ2 = HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
DD8 = MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
F55 = CHASSIS CONTINOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL VARIABLE TIME DAMPING
CHASSIS(F55)
FE2 = SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
JAF = BRAKE PROVISIONS EUROPE SPECIAL BRK PROVISIONS FOR EUROPE(JAF)
JJA = PT DRESS SUBASSEMBLY INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJA)
KJ5
LS3 = ENGINE GAS, 8 CYL, 6.2L, SFI, ALUM, HO, GM 6.2W(LS3)
MM6 = TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6-SPD M/TRANS(MM6)
MN6 = TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
QX1 = WHEEL 18 X 8.5 FRT & 19 X 10 RR, ALUMINUM, PAINTED FLANGLESS ALUM WHL(QX1)
SSG = GRAPHIC SWITCH FUNCTION SYMBOL GRAPHIC SYMBOL FUNCTION SW(SSG)
U3U = RADIO AM/FM STEREO, SEEK/SCAN, DVD, CD, CLOCK ETR, NAVIGATION, VOICE REC, MP3
UA2 = THEFT DETERENT SYS EXPORT SPECIFIC EXPORT SPECIFIC THEFT DETERENT SYSTEM(UA2)
UK3 = CONTROL STEERING WHEEL,ACCESSORY STEERING WHEEL ACSRY CONTROLS(UK3)
ULS = LOCK CONTROL STEERING COLUMN STRG COLUMN LOCK CONTROL(ULS)
VC5 = LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL USED OUTSIDE U.S. AND
JAPAN(VC5)
VH9 = ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9)
VT7 = OWNERS MANUAL ENGLISH LANGUAGE ENGLISH LANGUAGE OWNERS MANUAL(VT7)
W11 = NAVIGATION DISC DATA NAV DATA 1 NAVIGATION DISC(W11)
XBH = TIRE FRONT P245/40ZR18 BW HW4 (EMT) TIRE(XHB)
YPI = TIRE REAR P285/35ZR19 BW HW4 (EMT) TIRE(YPI)
Message par Sebcorvette76 Mar 7 Avr 2015 - 18:19
bon juste une incohérence pour la deuxième car elle serais de 2008 et elle est a vendre comme une 2010 une explication?
Sebcorvette76
Sebcorvette76
Message par Yann Mar 7 Avr 2015 - 18:57
Le 10 eme chiffre du VIN donne l'année millésime soit 2008!
Si cette voiture a été immatriculée pour la première fois en janvier 2010 le vendeur met 2010... mais il n'empeche que cela reste une 2008
Message par Sebcorvette76 Mar 7 Avr 2015 - 18:59
Yann a écrit:Le 10 eme chiffre du VIN donne l'année millésime soit 2008!
Ok merci pour l'info..
Sebcorvette76
Sebcorvette76
Message par Sebcorvette76 Sam 18 Avr 2015 - 8:11
Salut Yannn ,finalement j-ai commander ma vette voici son VIN un p'tit décodage est il possible stp?
1G1YY26WX85106904
Sebcorvette76
Sebcorvette76
Message par Yann Sam 18 Avr 2015 - 8:39
T'es pas reveillé ce matin ????
Message par Sebcorvette76 Sam 18 Avr 2015 - 9:14
Yann a écrit:T'es pas reveillé ce matin ????
mla vache t a raison lollll chuis à la ramasse désolé le ferais plus
Sebcorvette76
Sebcorvette76
Message par Yann Sam 18 Avr 2015 - 9:19
Remonte un tout petit peu ... mais vraiment un tout petit peu Mr.Red
Ca m'a donné l'occasion de le décoder pour la troisième fois. J'ai l'impression de perdre mon temps...
Message par Sebcorvette76 Sam 18 Avr 2015 - 12:34
Yann a écrit:Remonte un tout petit peu ... mais vraiment un tout petit peu Mr.Red
désolé vraiment désolé je te met un pack de bière de coté pour me faire pardonner passe quand tu veux boire un verre....
Sebcorvette76
Sebcorvette76
Message par Alec Sam 18 Avr 2015 - 12:42
Shocked Non , pas la bière , il va éclater.... Décodage VIN 839752 Décodage VIN 839752
Message par Sebcorvette76 Sam 18 Avr 2015 - 12:51
Alec a écrit:Shocked  Non , pas la bière , il va éclater.... Décodage VIN 839752 Décodage VIN 839752
bon ben j'ai d l eau de source aussi.............
Sebcorvette76
Sebcorvette76
