Décodage VIN
Décodage VIN
Bonjour à tous
Je souhaitais avoir un peu plus d'infos sur une C6 qui devrait etre ma future acquisition.
1G1YY26U865113507
Si quelq'un aurait la possibilité et lamabilité de me fournir ces infos..
1G1YY26U865113507
syl33- Short Block
- Nombre de messages : 91
Re: Décodage VIN
bonjour syl33 elle est de 2006 ta futur
rocca44- Blue Flame 6
- Nombre de messages : 152
Modele Vette : c5 ba et c6 bm
Re: Décodage VIN
Fabriquée en janvier 2006
VIN: 1G1YY26U865113507
VIN Decode
1:U.S. BUILT
G:GENERAL MOTORS, GENASYS L.C.
1:CHEVROLET
YY:CORVETTE
2:TWO-DOOR (07,08,77,87)
6:ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINT - FRONT, SIDE, & OCCUPANT SENSOR
U:ENG OPT - LS2 DISP - 6.0L CYL - V8 FUEL SYS - SFI DIV - 1,4,6 PROD IN - U.S.
8:CHECK DIGIT
6:2006 MODEL YEAR
5:BOWLING GREEN KY
113507: PRODUCTION SEQUENCE
RPO Codes
1SA = PACKAGE-OPTION 01 (1SA)
313 = TRIM COMBINATION LEATHER, LT CASHMERE (3) (04) LEATHER TRIM(313)
31I = INTERIOR TRIM LT CASHMERE (04) (31I)
74U = EXTERIOR COLOR,PRIMARY (74U)
AAB = MEMORY DRIVER CONVENIENCE PACKAGE DRIVER MEMORY CONVENIENCE PKG(AAB)
AG2 = ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
AJ7 = RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT & SIDE INFL RST FRT
& SI(AJ7)
AQ9 = SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AU8 = LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY REMOTE ENTRY LK CONT(AU8)
AX4 = RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) FRT & RR MAN RST SYS FOR
EUROPEAN VEHICLE(AX4)
B4H
BAG = PARTS PKG EXPORT PARTS PKG(BAG)
BGR
CE4 = WASHER,HEADLAMP,HIGH PRESSURE HDLP WA(CE4)
CF7 = ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7)
CJ2 = HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX
CONT(CJ2)
CT1 = COUNTRY,BELGIUM(EXPORT) BELGIUM(CT1)
D42 = COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
DD0 = MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DD8 = MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT
SENSITIVE(DD8)
E2C
EXP = EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP)
FE3 = SUSPENSION SYSTEM,SPORT SPORT SUSP(FE3)
GU6 = AXLE,REAR,3.42 RATIO 3.42R(GU6)
IL3 = TRIM,INTERIOR DESIGN INTERIOR TRIM DESIGN(IL3)
J55 = BRAKE SYSTEM,HEAVY DUTY POWER HVY DUTY PWR BRK(J55)
JAF = BRAKE PROVISIONS EUROPE SPECIAL BRK PROVISIONS FOR EUROPE(JAF)
K63 = GENERATOR 110 AMP 110 AMP GEN(K63)
KA1 = HEATER - SEAT ST HTR(KA1)
KNP = COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
KNR = COOLING SYSTEM AXLE AXLE COOLING SYSTEM(KNR)
KPS = OIL COOLER,ENGINE ENG OIL COOLER(KPS)
LS2 = ENGINE,6.0L(364CID) GAS V8 6.0-H(LS2)
MAE = MARKETING AREA EUROPE(EXPORT) EUROPE(MAE)
MN6 = TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS
PROVISIONS(MN6)
MZ6 = TRANSMISSION MAN 6 SPD, TREMEC, 85MM, 2.97 1ST, 0.71 5TH 0.57 6TH, O/D 6-SPD M/TRANS(MZ6)
NK4 = STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
NP7 = STEERING COLUMN(EXPORT) STRG COL(NP7)
NT4 = EMISSION SYSTEM EEC 05 EEC 05 EMIS(NT4)
QG6 = WHEEL 18 X 8.5 FRT & 19 X 10 RR, ALUMINUM, STYLED ALUM WHL(QG6)
R9I
SSG = GRAPHIC SWITCH FUNCTION SYMBOL GRAPHIC SYMBOL FUNCTION SW(SSG)
T62 = LIGHTING DAYTIME RUNNING ----DELETE T62)
T79 = LAMPS,REAR FOG RR FOG LP(T79)
T84 = HEADLAMPS,RH RULE OF THE ROAD,(MARKED E) RH RULE OF ROAD HDLP(T84)
T90 = LAMP,SIGNALING AND MARKER(EXPORT) SIGNAL & MARKER LAMP(T90)
T93 = LAMP,TAIL AND STOP(SPECIAL) SPECIAL TAIL & S/LP(T93)
U19 = SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR KPH SPEEDO(U19)
U3U = RADIO AM/FM STEREO, SEEK/SCAN, DVD, CD, CLOCK ETR, NAVIGATION, VOICE REC, MP3
RADIO,DVD,CD,CLK,NAV,VOICE RECOGNITION(U3U)
U52 = CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
U65 = SPEAKER SYSTEM 7,PREMIUM 7 SPKR SYSTEM,PREMIUM(U65)
UA2 = THEFT DETERENT SYS EXPORT SPECIFIC EXPORT SPECIFIC THEFT DETERENT SYSTEM(UA2)
UH3 = INDICATOR LOW TIRE PRESS, VAR 2 LOW TIRE PRESS IND(UH3)
UL2 = RADIO FREQUENCY(EUROPEAN) EUROPEAN RDO FREQ(UL2)
ULS = LOCK CONTROL STEERING COLUMN STRG COLUMN LOCK CONTROL(ULS)
US3 = ANTENNA DIVERSITY DIVERSITY ANTENNA(US3)
UV6 = DISPLAY,HEADUP HEAD UP DISPLAY(UV6)
V76 = HOOK,FRONT TOW(EXPORT) FRT TOW HOOK(V76)
V78 = VEHICLE STATEMENT(DELETE)(EXPORT) V78)VEHICLE STATEMENT-DELETE
VC5 = LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL USED
OUTSIDE U.S. AND JAPAN(VC5)
VH5 = PLATE,VEHICLE IDENTIFICATION(EXPORT) VEH ID PLT(VH5)
VJ4 = LABEL, EXPORT CHILD SEAT LOCATION LABEL CHILD SEAT LOCATION(VJ4)(EXPORT)
VL4 = LICENSE PLATE,FRONT MOUNTING PACKAGE EEC FRT LIC PLT MTG PKG FOR EEC(VL4)
W11 = NAVIGATION DISC DATA NAV DATA 1 NAVIGATION DISC(W11)
XGN = TIRE FRONT P245/40ZR18-88Y BW HW4 (EMT) HI-PERFORMANCE TIRE(XGN)
YGJ = TIRE REAR P285/35ZR19-90Y BW HW4 (EMT) HI-PERFORMANCE TIRE(YGJ)
Z51 = PERFORMANCE HANDLING PACKAGE PERF HDLG PKG(Z51)
VIN Decode
1:U.S. BUILT
1:CHEVROLET
YY:CORVETTE
8:CHECK DIGIT
6:2006 MODEL YEAR
5:BOWLING GREEN KY
RPO Codes
& SI(AJ7)
B4H
BGR
CONT(CJ2)
SENSITIVE(DD8)
E2C
PROVISIONS(MN6)
R9I
Yann- Administrateur
- Nombre de messages : 20106
Re: Décodage VIN
Tu peux trouver quelques infos ici >>>
http://www.vettefacts.com/C6/2006.aspx
- Nombre de messages : 20337
Re: Décodage VIN
Merci beaucoup de votre réactivité
syl33- Short Block
Re: Décodage VIN
Bonjour Yann,
Est-ce que je pourrai avoir le décodage de ce vin ?
1G1YY36U065108338
merci
Charly
1G1YY36U065108338
merci
Charly
