les évolutions de la C5 de 1997 à 2004
tout comme la C6 qui a évoluer tout au long de sa vie , avec la grosse évolution en 2008 et la LS3 , la C5 a elle aussi évoluer.
pour la C5 , 2001 représente l'équivalent du passage LS2/LS3 pour la C6
ci dessous la liste des améliorations faites par GM au fil du temps
1997
Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
All Z51 cars include: Power Steering Cooler, xx, xx, ??
97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
Convertible becomes available
Active Handling becomes available late in year
The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
1999
26# injectors substituted for 28#
Fuel pump revised to reduce noise
FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
HUD introduced
only one line in driver's side fuel rail cover (no fuel return line?)
Power telescoping wheel becomes an option
? Steering hardware changed to combat wandering
door sill trim plates added
2000
Millennium Yellow available
? "Thin Spoke" versus "wagon wheel" design wheels become standard.
Pup cats added to CA models for LEV emissions requirements (5hp loss relative to 97-99)
Steel swaybar endlinks instead of plastic on Z51 equipped cars
Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
No keyhole on passenger side doorhandle
Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
return to 28# injectors for all models.
Second Generation Active Handling
Nassau Blue discontinued
Alternator 'clutch' pulley added on A4 cars
New soundproofing + foam in all cars
Smaller keyfob
electrochromic dimming rearview and driver's mirrors
lighter AGM battery
Thickness + Material in vert change
Chrome exhaust tips for coupe + vert
85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
All Corvettes now have the LS6 intake manifold
All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
Hardtop/FRC discontinued
Pup cats added to all models
Stronger synchros in all transmissions
Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
metal valvestem caps (late year)
Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
Introduction of the Z06, which has as differences:
hardtop body style
rear brake ducting
screened inlets on front fascia, without foglights
F1 supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
new LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
Titanium exhaust system
lightweight windshield
New, stronger clutch with redesigned master + slave cylinder
Stronger rear differential (shotpeened ring gear)
Red brake calipers (otherwise identical)
Trans overtemp warning light on DIC
6500 redline gauges with special checkering + Z06 font
redesigned PCV system to help combat oil burning
Red LS6 Fuel Rail Covers (FRC's)
FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
Z06 Changes:
Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
Less restrictive intake airbox lid
Descreened MAF
Removal of pup-cats (total with changes = 405hp)
Z06 shocks revised with less rebound for better launching
Z06 brake pads revised for better stopping (generate more dust)
Lighter, sodium filled valves w/ stronger valvesprings
higher tension rings installed to prevent oil burning problems
slight piston redesign *
clutch strength upgraded.
HUD available on Z06 (not avail '01 model year)
Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
Electron Blue color offered
Steel endlinks changed to aluminum
Aluminum automatic transmission cooler case (all models)
AM/FM stereo with in-dash CD player now standard on Coupe and Convertible
AM/FM/Cassette only available with 12-disc CD changer on Coupe and Convertible
2003
Late model-year new fuel system design from C6's
2003 anniversary edition with Anniversary paint and decal option.
2004
Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
2004 Commemorative Editions. CE Z06 comes with carbon fibre hood and has decal package.
1997
1998
1999
HUD introduced
2000
2001
Smaller keyfob
lighter AGM battery
hardtop body style
rear brake ducting
2002
Z06 Changes:
Descreened MAF
2003
2004
supermot- Turbocharged
- Nombre de messages : 6365
Re: les évolutions de la C5 de 1997 à 2004
Lorsque l'on fait un copier/coller d'un article paru ailleurs merci de mettre au moins le lien de l'article original ...
Yann- Administrateur
- Nombre de messages : 20106
Le Voici
http://www.corvetteforum.com/forums/c5-general/1094713-c5-changes-from-year-to-year.html
» Photos de ma C5 full US, modèle 1997, en Suisse
» Souvenirs : Euro Meet Vette à Dijon Prenois en .... 1997 !!
» Evolutions C5 au fil du temps
» Zol en Z: évolutions de yellow bird.
» Evolutions de ma C6 .. choix difficile
