35 €
1957 CONCEPT Q X-84
1957 CONCEPT Q   X-84 Empty 1957 CONCEPT Q X-84
Message par Invité Mar 23 Fév 2010 - 8:52
GM worked on a large sedan with a front engine, rear transaxle, and independent rear suspension. Duntov proposed a front/mid-engine Corvette using the new transaxle and suspension, with gullwing doors that took half the windshield with them. This concept died in 1958 due to a recession.
In light of the 1997 5th generation Corvette, the 1957 Q-Corvette is not only the most forgotten Corvette, but the most profound of all concept Corvettes! Mechanical designs for the C5 were actually laid out in this very unique 1957 prototype.
Early in 1957, Chevrolet was in the beginning stages of developing a completely new small car concept that would eventually become the Corvair. Corvette designers saw that the transaxle and independent rear suspension from the Corvair could be used to develop a totally new and revolutionary Corvette. With this exotic piece of hardware, Zora Arkus-Duntov and his designers saw this as a golden opportunity for a new and very different Corvette for 1960.
The rear mounted transmission/axle helped balance the weight of the Corvette. Drum brakes were mounted inboard to reduce unsprung weight. Even the starter motor was on the transaxle for weight balancing. The transaxle case was aluminum and could be offered as either a 4-speed manual or automatic.
Up front an all-aluminum, fuel-injected 283 engine with a dry-sump oil system was proposed. There were to be no steel valve guides, valve seats or piston sleeves. This was to help achieve the target weight of 2,225 pounds.
The proposed structure of the Q-Corvette was a steel platform similar to the 356 Porsche. Because of the transmission location, the interior would have been larger, even though the length and height were smaller than the production Corvette. The fastback roof had a permanent arch behind the cockpit and removable roof panels. At the leading edge of the windshield, there were no A-pillars.
Bill Mitchell suggested to stylists Bob Veryzer and Pete Brock that the styling should come from the slimness of the Pininfarina / Abarth cars with a strong horizontal line and bulges over the wheels in the upper surfaces. The pointed nose had driving lights in the grille opening and manually operated pop-up headlights. Mitchell’s Sting Ray Racer used most of the same styling ideas.
In 1958 there was a recession in the automobile industry, so GM killed the expensive Q-Corvette project. As it was, Corvettes were hardly profitable. So the Q-Corvette was an on-paper and clay-only prototype with some great ideas that took 30 years to produce.
1957 CONCEPT Q   X-84 1957_c101957 CONCEPT Q   X-84 1957_c111957 CONCEPT Q   X-84 1957_c12
la C2 était née ! 1957 CONCEPT Q   X-84 000204AE
