Vin
Vin
Quelqu'un peut me sortir les spec de ce vin .
1G1Y93DE6D5700025.
Merci beaucoup
1G1Y93DE6D5700025.
Merci beaucoup
mwelche- Turbocharged
- Nombre de messages : 1589
Modele Vette : ---------
Re: Vin
VIN: 1G1Y93DE6D5700025
VIN Decode
1:U.S. Built
G:General Motors
1:Chevrolet Passenger Car
Y9:Chevrolet Corvette (Export - Non US, Non Canada)
3:Coupe, 2 - Door, Convertible (67)
D:Active Manual Belts, Airbags-Driver & Passenger - Front (1st row), & Front Seat Side (1st row)
E:LS7 - Engine Gas, 8 CYL, 7.0L, SFI, ALUM
6:Check Digit
D:2013 Model Year
5:Bowling Green Kentucky
700025: PRODUCTION SEQUENCE
RPO Codes
10U = COULEUR EXTÉRIEURE, BLANC ARCTIQUE (10U)
1SE = GROUPE-OPTION 05 (1SE)
205 = COMBINAISON DE GARNITURE DE CUIR, ÉBÈNE/BLEU FONCÉ GARNITURE EN CUIR(205)
20I = GARNITURE INTÉRIEURE ÉBÈNE / BLEU FONCÉ COULEUR DE GARNITURE INTÉRIEURE (20I)
34T = COULEUR PRINCIPALE BLEU WAGONER COULEUR PRINCIPALE(34T)
427
5A7 = ROUE DE SECOURS, SUPPRESSION 5A7)
6X1 = SELECTOR DE SUSPENSION DE LA COMPOSANTE AVANT GAUCHE NON-INFORMATISÉ
SUSPENSION (6X1)
7X1 = DÉSÉLECTION DE L'ORDINATEUR DE LA SUSPENSION AVANT DROITE SUSP(7X1)
8X2 = SELECTOR DE SUSPENSION DE LA COMPOSANTE AVANT DROITE NON-INFORMATISÉ
SUSPENSION (8X2)
9L3 = SUPPRESSION DU PNEU DE RECHANGE 9L3)
9X2 = COMPOSANT NON INFORMATISÉ DE SUSPENSION ARRIÈRE DROITE SUSPENSION (9X2)
AAB = CENTRE DE COMMODITÉ À MÉMOIRE DU CONDUCTEUR. TROUSSE D'AGRÉMENT
CONDUCTEUR À MÉMOIRE (AAB)
AG2 = DISPOSITIF DE RÉGLAGE À COMMANDE ÉLECTRIQUE DU SIÈGE PASSAGER, ORIENTABLE
DISPOSITIF DE RÉGLAGE DE SIÈGE PASSAGER ORIENTABLE (AG2)
AJ7 = DISPOSITIF DE PROTECTION FRT SEAT, GONFLABLE, CONDUCTEUR ET PASSAGER, AVANT ET
LATÉRAL SAC GONFLABLE AVANT ET LATÉRAL (AJ7)
AJK = SIÈGE À COMMANDES, COUSSIN À RÉGLAGE ÉLECTRIQUE, SUPPORT LOMBAIRE À RÉGLAGE
ÉLECTRIQUE RÉGLAGE ÉLECTRIQUE DU SUPPORT LOMBAIRE ET DU COUSSIN DU SIÈGE(AJK)
AL0 = CAPTEUR INDICATEUR DE DISPOSITIF SUPPLÉMENTAIRE DE PROTECTION, DÉTECTEUR DE
PRÉSENCE DE PASSAGER AVANT/D'ENFANT DÉTECTEUR DE PRÉSENCE DE PASSAGER/ENFANT AU
SIÈGE AVANT, TÉMOIN DE CAPTEUR DU DISPOSITIF DE RETENUE GONFLABLE (AL0)
AP9 = FILET,ARRIM FILET DE SÉCURITÉ (AP9)
AQ9 = SIÈGE, BAQUET AVANT, CONDUCTEUR, PASSAGER, INCLINABLE SIÈGE BAQUET AVANT
INCLINABLE, DE LUXE (AQ9)
AX4 = DISPOSITIF DE PROTECTION, SIÈGE AVANT ET ARRIÈRE, MANUEL (EUROPE) DISPOSITIF DE
RETENUE MANUEL AVANT ET ARRIÈRE POUR VÉHICULE EUROPÉEN (AX4)
AXJ = TYPE DE VÉHICULE = DE TOURISME VÉHICULE DE TOURISME (AXJ)
B92 = CAPOT EN FIBRE DE CARBONE CAPOT EN FIBRE DE CARBONE(B92)
BAG = ENSEMBLE DE PIÈCES POUR MARCHÉ D'EXPORTATION ENSEMBLE DE PIÈCES(SAC)
BGR
CE4 = RONDELLE, PHARE, HAUTE PRESSION LAVE-PHARES (CE4)
CJ2 = CHAUFFAGE, VENTILATION ET CLIMATISATION AVANT, COMMANDE DE TEMPÉRATURE
AUTOMATIQUE, COMMANDE DE TEMPÉRATURE AUXILIAIRE. COMMANDE AUTO/AUX AV. DE LA
CLIMAT. (CJ2)
CM7 = TOIT DÉCAPOTABLE, OUVRANT, À COMMANDE ÉLECTRIQUE TOIT DÉCAPOTABLE À
COMMANDE ÉLECTRIQUE(CM7)
CW2 = PAYS DU GOLFE (BAHREÏN, OMAN, QATAR, ÉMIRATS ARABES UNIS (UAE)) ÉTATS DU GOLFE
PERSIQUE (CW2)
DD0 = RÉTROVISEUR, EXTÉRIEUR, GAUCHE ET DROIT, COMMANDE À DISTANCE, DÉGIVREUR
ÉLECTRIQUE, SENSIBLE À LA LUMIÈRE RÉTROVISEUR EXTÉRIEUR À COMMANDE ÉLECTRIQUE (DD0)
© 2014 General Motors - Date de publ. : mar 2013 (US) Page 1 of 3
http://pc-epc:351/PQMace/appf.fve?fid=vehicleInfo&mid=gmna&action=getVehicleI... 04/05/2014
DD8 = RÉTROVISEUR INTÉRIEUR, INCLINAISON, AUTOMATIQUE, PHOTOSENSIBLE RÉTROVISEUR
INTÉRIEUR, PHOTOSENSIBLE (DD8)
DNS = ÉQUIPEMENT INSTALLÉ CHEZ LE FOURNISSEUR ÉQUIPEMENT INSTALLÉ CHEZ LE
FOURNISSEUR (DNS)
EXP = EXPORTATION, I.E.S. EXPORTATION I.E.S. ÉQUIPEMENT ZONE DE MARCHÉ SPÉCIFIQUE EXPORT
(EXPORT)
F55 = CHÂSSIS, MAGNÉTO RHÉOLOGIQUE À AMORTISSEMENT EN TEMPS RÉEL, À VARIATION
CONSTANTE CHÂSSIS À AMORTISSEMENT EN TEMPS VARIABLE (F55)
FE3 = SYSTÈME DE SUSPENSION,SPORT SUSPENSION SPORT (FE3)
FE9 = HOMOLOGATION FÉDÉRALE CONCERNANT LES ÉMISSIONS NORMES FÉDÉRALES
ANTIPOLLUTION (FE9)
FHO = CARBURANT DE VÉHICULE ESSENCE E10 CARBURANT DE TYPE ESSENCE E10
GU6 = RAPPORT DE PONT ARRIÈRE ,3.42 3.42R(GU6)
H33 = COULEUR DE COLLERETTE DE PHARES, CYBER-GRIS COULEUR DE COLLERETTE DE PHARES
(H33)
IL5 = GARNITURE D'AMÉNAGEMENT INTÉRIEUR CONCEPTION DE GARNITURE INTÉRIEURE (IL5)
J56 = ALIMENTATION DU SYSTÈME DE FREINAGE, DISQUE AVANT ET ARRIÈRE, ANTIBLOCAGE, ROUE
AVANT ET ARRIÈRE, ROBUSTE (HEAVY DUTY) FREINS ANTIBLOCAGE ROBUSTES (HEAVY DUTY) (J56)
J6D = ÉTRIER DE FREIN DE COULEUR GRIS FONCÉ (DARK GREY) MÉTALLIQUE COULEUR DE L'ÉTRIER
DE FREIN (J6D)
JJB = SOUS-ENSEMBLE DE COUVERCLE PROTECTEUR NON INSTALLÉ (MÉTHODE D'OPTIMISATION
MODULAIRE SEULEMENT) EXPLOITATION D'USINE(JJB)
K63 = ALTERNATEUR 110 AMPÈRES GÉNÉRATRICE DE 110 AMPÈRES (K63)
KA1 = CHAUFFAGE - SIÈGE SIÈGE CHAUFFANT (KA1)
KJ5
KNP = SYSTÈME DE REFROIDISSEMENT,TRANSMISSION,HAUTE RÉSISTANCE CIRCUIT DE
REFROIDISSEMENT DE TRANSMISSION À GRAND RENDEMENT (KNP)
KNR = SYSTÈME DE REFROIDISSEMENT D'ESSIEU SYSTÈME DE REFROIDISSEMENT D'ESSIEU (KNR)
KPS = REFROIDISSEUR D'HUILE, MOTEUR REFROIDISSEUR D'HUILE (KPS)
LS7 = MOTEUR, CARB., 8 CYL., 7.0 L/(425 CYLINDRÉE), INJ. MULTIPOINT SÉQUENTIELLE DE CARB.,
ALUM, HO, GM 7.0E (LS7)
MM6 = BOÎTE MANUELLE 6 VITESSES, BORG WARNER, 85MM, 1RE 2.66, 6E 0.50, SURMULTIPLIÉE BOÎTE
DE VITESSES MANUELLE 6 VITESSES (MM6)
N37 = COLONNE DE DIRECTION, INCLINABLE ET TÉLESCOPIQUE VOLANT DE DIRECTION INCLINABLE
ET TÉLESCOPIQUE (N37)
NE9 = SYSTÈME ANTIPOLLUTION CEE 09. COMMANDE ÉLECTRONIQUE DU MOTEUR 09 ÉMISSION
(NE9)
NK4 = COLONNE DE DIRECTION, SPORT, CUIR ROUE SPORT (NK4)
NPP = RENDEMENT DU SYSTÈME D'ÉCHAPPEMENT SYSTÈME D'ÉCHAPPEMENT RENDEMENT (NPP)
OAR = IDENTIFICATION PRÉ-PRODUCTION ('NUMÉRO DE LOT DU PROCÉDÉ DE FABRICATION)
VÉHICULE DE PRÉPRODUCTION (OAR)
Q8K = ROUE 19 X 10.0, J, AVANT ET 20 X 12.0, J, ARRIÈRE, ALUMINIUM, CONCEPTION 9 ROUE EN
ALUMINIUM(Q8K)
R60 = TROUSSE PERFORMANCE 60E ANNIVERSAIRE 427 DÉCAPOTABLE TROUSSE PERFORMANCE
DÉCAPOTABLE 427 60E ANNIVERSAIRE(R60)
SSG = SYMBOLE DE FONCTION D'INTERRUPTEUR GRAPHIQUE INTERRUPTEUR DE LA FONCTION DES
SYMBOLES GRAPHIQUES (SSG)
T43 = DÉFLECTEUR, ARRIÈRE DÉFLECTEUR ARRIÈRE (T43)
T62 = FEUX DE CIRCULATION DE JOUR ----SUPPRIMER T62)
U19 = INDICATEUR DE VITESSE, INSTRUMENT, KILOMÈTRES À L'HEURE INDICATEUR DE VITESSE
KM/H (U19)
U3U = RADIO AM/FM STÉRÉO, RECHERCHE/BALAYAGE, DVD, CD, HORLOGE, RÉGLAGE D'ACCORD
ÉLECTRONIQUE, NAVIGATION, ENREGISTREMENT VOCAL, MP3 RADIO, LECTEUR DE DVD, LECTEUR
DE CD, HORLOGE, NAV., RECONNAISSANCE DE LA VOIX (U3U)
U52 = ENSEMBLE D'INSTRUMENTS(ÉLECTRONIQUE) ENSEMBLE DES INDICATEURS ÉLECTRONIQUES
(U52)
U65 = ENCEINTE 7, DE HAUT-PARLEURS DE QUALITÉ SYSTÈME DE QUALITÉ SUPÉRIEURE À 7 HAUTPARLEURS
(U65)
UD4 = ALARME DE VITESSE DU VÉH. (120 KM/H) 120 KPH ALARME(UD4)
UJM = TÉMOIN DE PRESSION DE PNEUS SELON LES RECOMMANDATIONS DU MANUEL TÉMOIN DE LA
PRESSION DES PNEUS RECOMMANDÉE DANS LE MANUEL (UJM)
UK3 = COMMANDE DU VOLANT DE DIRECTION, ACCESSOIRE COMMANDES ACCESSOIRES DU
VOLANT DE DIRECTION(UK3)
UL2 = FRÉQUENCE RADIO (MARCHÉ EUROPÉEN) FRÉQUENCES RADIOS EUROPÉENNE (UL2)
US3 = ANTENNE DIVERSITÉ ANTENNE DIVERSITÉ (US3)
© 2014 General Motors - Date de publ. : mar 2013 (US) Page 2 of 3
UV6 = AFFICHAGE, TÊTE HAUTE VISUALISATION TÊTE HAUTE (UV6)
V76 = CROCHET, REMORQUAGE AVANT (EXPORTATION) CROCHET DE REMORQUAGE AVANT(V76)
V87 = DÉCLARATION DE VÉHICULE, ORGANISATION DES ÉTATS DU GOLFE DÉCLARATION DU
VÉHICULE POUR LES ÉTATS DU GOLFE ORG (V87)
VBX = LANGUE DE L'ÉTIQUETTE : ARABE ÉTIQUETTE EN LANGUE ARABE (VBX)
VC5 = ÉTIQUETTE - EXPÉDITION, SAUF LES ÉTATS-UNIS, POSSESSIONS É.-U. OU ÉTIQUETTE
JAPONAISE ÉTIQUETTE D'EXPÉDITION UTILISÉE HORS ÉTATS-UNIS ET JAPON (VC5)
VH9 = ENVELOPPE, MANUEL DE RENSEIGNEMENTS DU PROPRIÉTAIRE GUIDE DE RENSEIGNEMENTS
AU PROPRIÉTAIRE, ENV. (VH9)
VL4 = PLAQUE D'IMMATRICULATION, ENSEMBLE DE MONTAGE AVANT POUR CEE ENSEMBLE DE
MONTAGE DE PLAQUE D'IMMATRICULATION AVANT POUR CEE (VL4)
VPH = PRÉPARATION DU VÉHICULE POUR LIVRAISON OUTRE-MER PRÉPARATION DU VÉH,
LIVRAISON OUTRE-MER (VPH)
W12 = DISQUE DE NAVIGATION, DONNÉES DE NAVIGATION 2 DISQUE DE NAVIGATION (W12)
WG4 = CONVERSION DE MODÈLE GRAND SPORT CORVETTE GRAND SPORT(WG4)
XFG = PNEU AVANT P285/30ZR19 BW TL HW4 EMT PNEU(XFG)
XL8 = FRÉQUENCES 433 MHZ FRÉQUENCE 433 MHZ (XL8)
Z16 = ENSEMBLE DÉCORATIF, ÉDITION SPÉCIALE ÉDITION SPÉCIALE (Z16)
Z25 = TROUSSE APPARENCE 60E ANNIVERSAIRE(ÉDITION LIMITÉE) 60E ANNIVERSAIRE(Z25)
Z30 = TROUSSE PERFORMANCE DES BANDES 60E ANNIVERSAIRE TROUSSE DE LA BANDE 60E
ANNIVERSAIRE(Z30)
Z51 = ENSEMBLE PERFORMANCE HANDLING ENSEMBLE PERFORMANCE HANDLING (Z51)
Z52 = ENSEMBLE MARCHANDISÉ DE SYSTÈME À CARTER SEC ENSEMBLE POUR SYSTÈME À CARTER
SEC (Z52)
Z5X = RÉTROVISEUR, DISPOSITIONS, LANGUE ARABE (EXPORTATION) ENSEMBLE RÉTROVISEUR
CONVERSION EN LANGUE ARABE (Z5X)
© 2014 General Motors - Date de publ. : mar 2013 (US) Page 3 of 3
VIN Decode
1:U.S. Built
G:General Motors
6:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
CLIMAT. (CJ2)
PERSIQUE (CW2)
FOURNISSEUR (DNS)
(EXPORT)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
KJ5
(NE9)
ALUMINIUM(Q8K)
KM/H (U19)
(U52)
(U65)
ANNIVERSAIRE(Z30)
SEC (Z52)
Yann- Administrateur
- Nombre de messages : 20106
Re: Vin
Mon ami,Le "sequence number" est hyper bas !
OAR = IDENTIFICATION PRÉ-PRODUCTION ('NUMÉRO DE LOT DU PROCÉDÉ DE FABRICATION).
Une « PILOT » avec un VIN et JobNumber identique …
Whhha !La vache
" it will offer a unique VIN sequence coveted by all collectors"
http://www.corvettemuseum.org/specs/2013/60_427_HeroCard_Final.pdf
N’hésites pas !si,tu as besoin de moi.
Whhha !La vache
Friendship 7- Turbocharged
- Nombre de messages : 6469
Re: Vin
Merci beaucoup Yann très sympa de ta part .
Oui je me pose vraiment des questions il n'y aura pas une deuxième chance j'ai toujours aimé la 427 , il y a déjà une personne dessus , le proprio est en déplacement retour fin de semaine , je n.arrive plus a dormir cela trotte dans ma tête .
Une bonne vette Friendships ?
Re: Vin
J'avais oublié de te donner la date de fabrication: 23 avril 2012.
Re: Vin
Yann a écrit:J'avais oublié de te donner la date de fabrication: 23 avril 2012.
Merci , donc model 2012 et non 2013 comme sur le dit le vendeur .
Re: Vin
Pas forcément , le mois de bascule est avril ou mai pour l'année ?
Re: Vin
Millesime 2013
pour info l'année est donnée par le 10eme caractère du VIN
voir tableau ci dessous:
http://en.wikibooks.org/wiki/Vehicle_Identification_Numbers_(VIN_codes)/Model_year
Re: Vin
Les années de production ce font de Juin à Juin.
Etant un véhicule de pré-production, elle est fabriquée avant que la production officielle ne commence.
C’est la 25em de cette série de 427 voitures.
Dans mes recherches …sur ces spécimens, j’ai remarqué qu’il y a toujours une PILOT pour chaque continent.
Il faudrait décoder plusieurs VIN pour avoir une idée du nombre de PILOT VEHICLE dans cette série.
….. Ce modèle est rare et en PILOT VEHICLE tu ne risques pas dans croiser une autre sur ta route.
Enfin, si tu veux faire de la collection avec celle la...t’a tout bon !
Je te conseille de joindre Whizz pour avoir son avis ou me passer un coup de fils !
Re: Vin
Une âme charitable pour décoder ces 4 VIN ? .SVP
1G1Y73DEXD5700082
1G1Y73DEXD5700843
1G1Y73DE2D5700769
1G1Y73DEXD5701877
1G1Y73DEXD5700082
1G1Y73DEXD5700843
1G1Y73DE2D5700769
1G1Y73DEXD5701877
Re: Vin
Friendship 7 a écrit:Les années de production ce font de Juin à Juin.
Merci mon Ami , passe moi ton numero par MP , je vais craquer si cela continu et je vais me retrouver avec deux Z .
j'espere qu'elle ne partira pas rapidement a moins que la personne qui est dessus est un passionne de corvette , et connaisseur !!!!
Re: Vin
Je te fais ca FS ...
Re: Vin
Merci Yann !!
Le MP vient de partir Mwelche .
Re: Vin
La premiere 0082 fabriqué le 7 mai 2012
VIN: 1G1Y73DEXD5700082
VIN Decode
1:U.S. Built
G:General Motors
Y7:Chevrolet Corvette 427 60th Anniversary (Manual)
X:Check Digit
D:2013 Model Year
700082: PRODUCTION SEQUENCE
RPO Codes
1SC = GROUPE - OPTION 03 (1SC)
1SZ = GROUPE- OPTION (1SZ)
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
CFZ = ENSEMBLE PERFORMANCE FIBRE DE CARBONE ENSEMBLE PERFORÉ EN FIBRE DE CARBONE
(CFZ)
CLIMAT. (CJ2)
05/05/2014
FOURNISSEUR (DNS)
EF7 = PAYS, ÉTATS-UNIS D'AMÉRIQUE (É.-U.) U S A(EF7)
ERI = ÉQUIPEMENT D'ÉCONOMIE D'ÉNERGIE DE LA BATTERIE ÉQUIPEMENT DE BATTERIE SAVER
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
JL5 = COMMANDE - BOÎTE DE VITESSES MANUELLE, SAUT DE VITESSE DE PREMIÈRE À QUATRIÈME
COMMANDE DE SAUT DE 1E À 4E VITESSES (JL5)
NT7 = NORMES FÉDÉRALES ANTIPOLLUTION, ÉLIMINATION PROGRESSIVE DU NIVEAU 2 NORMES
FÉDÉRALES ANTIPOLLUTION, ÉLIMINATION PROGRESSIVE DU NIVEAU 2 (NT7)
ALUMINIUM(Q8K)
R9N
SLM
U2K = SYSTÈME AUDIO NUMÉRIQUE - BANDE S SYSTÈME AUDIO NUMÉRIQUE - BANDE S (U2K)
(U52)
(U65)
UE1 = SYSTÈME DE COMMUNICATION DU VÉHICULE, G.P.S. 1 GPS 1 SYSTÈME DE COMMUNICATION
DU VÉHICULE(UE1)
UG1 = COMMANDE D'OUVRE-PORTE DE GARAGE UNIVERSELLE OUVRE-PORTE DE GARAGE
UNIVERSEL (UG1)
UPF = INTERFACE SANS FIL GAMME COURTE, RÉCEPTION VOCALE INTERFACE SANS FIL COURTE
PORTÉE/BLUETOOTH AVEC RECONNAISSANCE VOCALE(UPF)
V8D = ENREGISTREMENT DU VÉHICULE- ÉTATS-UINIS ENREGISTREMENT DE VÉHICULE AMÉRICAIN
(V8D)
VA5 = ÉTIQUETTE DE LANGUE (ANGLAIS) ÉTIQUETTE DE LANGUE ANGLAISE (VA5)
VDD
VK3 = PLAQUE D'IMMATRICULATION, ENSEMBLE DE FIXATION AVANT TROUSSE DE MONTAGE DE
PLAQUE D'IMMATRICULATION AVANT (VK3)
VT7 = GUIDE DE L'AUTOMOBILISTE EN LANGUE ANGLAISE MANUEL DU PROPRIÉTAIRE ANGLAIS
(VT7)
XL7 = FRÉQUENCES NOMINALES 315 MHZ LONGUE DISTANCE, FRÉQUENCE 315 MHZ (XL7)
ANNIVERSAIRE(Z30)
SEC (Z52)
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
05/05/2014
FOURNISSEUR (DNS)
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
SLM
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
Re: Vin
la 0843 fabriquée le 4 Aout 2012
VIN: 1G1Y73DEXD5700843
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
700843: PRODUCTION SEQUENCE
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
E2C
(ERI)
ANTIPOLLUTION (FE9)
(H33)
I13 = ENGINEERING YEAR 2013 ENGINEERING YEAR 2013(I13)
DE FREIN (J6D)
Q6B = ROUE 19 X 10 AVANT ET 20 X 12 ARRIÈRE, ALUMINIUM, MOULÉ, CHROME ROUE EN
ALUMINIUM (Q6B)
R9N
R9Z
SLL = COMMANDES VENDUES COMM VENDUE(SLL)
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
VDN
VEB = ENSEMBLE COUVRE-PÉDALE ACCESSOIRE ENSEMBLE COUVRE-PÉDALE ACCESSOIRE (VEB)
VLN = ACCESSORY WINDSCREEN PARE-BRISE ACCESSOIRE(VLN)
(VT7)
VZD = NIV ANNÉE MODÈLE 2013 2013 VIN MODEL YEAR(VZD)
YM8 = IDENTIFICATION DES OPTIONS DE PERSONNALISATION LIMITÉE **OPTION DE PRODUCTION
LIMITÉE INSTALLÉE PAR LE CONCESSIONNAIRE **
ANNIVERSAIRE(Z30)
SEC (Z52)
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
E2C
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM (Q6B)
R9N
R9Z
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
VDN
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
Re: Vin
la 769 fabriquée le 9 Aout 2012
VIN: 1G1Y73DE2D5700769
VIN Decode
1:U.S. Built
G:General Motors
2:Check Digit
D:2013 Model Year
700769: PRODUCTION SEQUENCE
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
SLM
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
VDN
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
VIN Decode
1:U.S. Built
G:General Motors
2:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
SLM
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
VDN
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
Re: Vin
T'es gentil FLO de confirmer ....
Re: Vin
la 1187 fabriquée le 20 décembre 2012
VIN: 1G1Y73DEXD5701877
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
701877: PRODUCTION SEQUENCE
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
SLM
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
SLM
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
Re: Vin
De mon cote j'ai rendez vous ce samedi avec le vendeur .
Re: Vin
Merci pour le coup de tel. très Sympathique
Merci Yann ! Au top !!
Perso...je n'ai pas retrouvé le code : OAR = IDENTIFICATION PRÉ-PRODUCTION ('NUMÉRO DE LOT DU PROCÉDÉ DE FABRICATION).
ça voudrait dire qu'il y a moins de 82 ...427 60th Anniversary de présérie.
il faudrait trouver d'autre Vette de cette série avec un VIN inférieur à 00082 ....et, refaire des décryptages.
En moyenne sur les C5 ...c'est 60 .
Par contre sur la série des C5 INDY PACE CAR ...il y en a 5 !
Moins de 82 ...ça pète déjà !! sur un modèle si rare.
le truc qui me fait halluciner .."Une présérie .....avec un JobNumber de 2013 ."
les Corvette de préséries porte un JobNumber de l'année précédente.
Un cas rarissime !
la pub précise que les VIN correspondent au job number (qui n'est jamais la cas) elles deviennent alors collector!
Mais, une présérie avec le même Job Number de la même année .... c'est exceptionnel .
Un cas rarissime !
Re: Vin
Bon …j’ai joué à la loterie ce soir devant la TV.
J’ai trouvé ces VIN (si, Yann est motivé pour nous suivre car il faudrait les décoder ).
Y a-t-il des "PILOT VEHICLE " !!??
1G1Y73DEXD5700034
1G1Y73DEXD5700048
1G1Y73DEXD5700079
Merci d’avance !
1G1Y73DEXD5700034
1G1Y73DEXD5700048
1G1Y73DEXD5700079
Merci d’avance !
Re: Vin
0034 fabriquée le 2 Mai 2012
VIN: 1G1Y73DEXD5700034
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
700034: PRODUCTION SEQUENCE
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
E2C
(H33)
DE FREIN (J6D)
NU1 = SYSTÈME ANTIPOLLUTION, NORMES CALIFORNIENNES, FAIBLES ÉMISSIONS 2 NORMES
CALIFORNIENNES D'ÉMISSIONS DE NIVEAU 2 (NU1)
ALUMINIUM(Q8K)
R9N
R9Z
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
VG6 = ÉTIQUETTE DU VÉHICULE, AVIS À L'ACHETEUR, CONCERNANT L'IMPACT SUR LE PARE-CHOCS
À 5 M/H (CALIFORNIE) ÉTIQUETTE - IMPACT SUR LE PARE-CHOCS, ,5 MI/H (CALIF) (VG6)
(VT7)
YF5 = HOMOLOGATION CONCERNANT LES ÉMISSIONS DE L'ÉTAT DE LA CALIFORNIE CONFORME
AUX NORMES CALIFORNIENNES RELATIVES AUX ÉMISSIONS POLLUANTES (YF5)
ANNIVERSAIRE(Z30)
SEC (Z52)
la 0048 fabriquée le 3 Mai 2012
VIN: 1G1Y73DEXD5700048
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
700048: PRODUCTION SEQUENCE
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
E2C
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
R9Z
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
la 0079 fabriquée le 7 Mai 2012
VIN Decode
1:U.S. Built
G:General Motors
2:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
SLM
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
VDN
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
E2C
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
R9Z
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
VIN Decode
1:U.S. Built
G:General Motors
X:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
E2C
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
R9Z
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
VIN Decode
1:U.S. Built
G:General Motors
2:Check Digit
D:2013 Model Year
RPO Codes
427
SUSPENSION (6X1)
SUSPENSION (8X2)
BGR
(CFZ)
CLIMAT. (CJ2)
FOURNISSEUR (DNS)
(ERI)
ANTIPOLLUTION (FE9)
(H33)
DE FREIN (J6D)
ALUMINIUM(Q8K)
R9N
SLM
(U52)
(U65)
DU VÉHICULE(UE1)
UNIVERSEL (UG1)
(V8D)
VDD
VDN
(VT7)
ANNIVERSAIRE(Z30)
SEC (Z52)
