RPO de ma corvette
RPO de ma corvette
j ai sur l étiquette le 1SA sui correspond :
1SA Corvette Base Equipment Group. Includes standard bucket seats and 4 speed automatic. 1997-2000 models included Delco Cassette radio. 2001-2002 models included Delco CD radio, 6 way power drivers seat and Active Handling. 2003-2004 models added dual zone electronic A/C. All model years included leather seats. No cost.
le reste des options :
1SB Coupe Equipment Group included: sport bucket seats, 6 way power passenger seat, dual zone A/C, fog lamps, memory package and luggage/parcel shade.
1SB Convertible Equipment Group included: sport bucket seats, 6 way power passenger seat, dual zone A/C, fog lamps, memory package, twilight sentinel and electrochromic mirrors.
1SC Coupe Equipment Group included all of the 1SB equipment plus: electrochromic mirrors, HUD, twilight sentinel and power-telescopic steering column.
1SC Convertible Equipment Group included all of the 1SB equipment plus: HUD and power-telescopic steering column.
Si je prends en compte le descriptif des autres options, je devrais avoir le 1Sc, quelqu'un a une explication ?
Stef84- Blown
- Nombre de messages : 1354
Re: RPO de ma corvette
oups pas pris les bons :
1SX Corvette Coupe Base Equipment Group
Dual Zone Auto HVAC, Keyless access with pushbutton start, HID Head Lamps with automatic exterior lamp control, Active Handling, Sound System with CD Player and MP3 playback, Fog lamps, Rear Luggage Shade, Parcel Net, Power Hatch Release.
1SA Option Package Includes above 1SX plus:
Side Air Bags, Custom Sport Adjustable Seats, Power Passenger Seat, Electrochromic Rear View, drivers side mirrors, Air Filtration - includes pollen filter
1SB Option Package Includes above +
6 Disk in dash CD changer with MP3 playback, driver's side memory package, head-up display, home link transmitter, auto dimming mirrors with compass power telescopic steering column, heated driver and passenger seats.
Si je prends en compte le descriptif des autres options, je devrais avoir le 1SB en partie, quelqu'un a une explication ?
Stef84- Blown
Hein!!!
What dis you say ??
Was sagst du ?
Spreichen sie französich?
What dis you say ??
Was sagst du ?
kojak67- Turbocharged
- Nombre de messages : 5726
Moi, pas comprendre
Si ta voiture est 1SA, pourquoi veux tu avoir des options propres au 1SB ?
Costou- Turbocharged
- Nombre de messages : 4015
c est bien pour ça que je pose la question
dans la boite à gant j'ai pris tous les groupes, j ai 1SA mais à coté de ça, j ai (si mon anglais est pas trop mauvais) ces options là du 1SB:
head-up display
donc est ce que ce sont des options que l on peut prendre à part, mal indiqué sur la voiture, ou spécial "europe"
head-up display
Stef84- Blown
Je comprend mieux!
D'après le registre suivant, tu peux voir le options possibles, mais j'ai peur que ce soit pour les modèles US. Pour les séries Europe, je ne sais pas s'il s'agit de séries spéciales ou simplement que des options US sont forcément incluses ( exemple: la mienne est 1SB, mais je n'ai pas le chargeur 6 CDs !).
http://www.c6registry.com/facts/2005.htm
c est ce lien que j ai utilisé et un autre je crois, je suis arrivé à ca :
AAB Memory Driver Convenience Package
AG2 Adjuster Passenger Seat Power, Multi-Directional
AJ7 Restraint System Seat, Inflatable, Driver and Passenger, Front and Side
AQ9 Seat Front Bucket, Passenger, Driver, Recliner
AU8 Lock Control, Entry Remote Entry, Specific Frequency
AX4 Restraint Conversion Seat, Manual, European
BAG Parts Package Export
BGR Plant Code Bowling Green, KY, USA
B4H Modification Noise Control, Export
CE4 Washer Headlamp, High Pressure
CF7 Roof Hatch, Removable, Non-Transparent
CJ2 HVAC System Air Conditioner Front, Automatic Temperature Control, Auxiliary Temperature Control
CT1 Country Belgium
DD0 Mirror Outside Left and Right, Remote Control, Electric, Heated Light Sensitive
DD8 Mirror Inside Rearview Light Sensitive
D42 Shade Rear Compartment
EXP Export I.E.S
E2C Order to Delivery Expedite to Customer C6 Corvette RPO Codes
FE3 Suspension System Sport
G90 Axle Rear-3.15 Ratio
IL3 Trim Interior Design (L3)
J55 Brake System Heavy Duty
KA1 Heater Seat, Front
KNR Cooling System Axle
KPS Cooler Oil, Engine
K63 Generator 110 amp
LS2 Engine, Gas, 8 CYL, 6.0L, SFI, Aluminum, GM
MAE Marketing Area Europe
MX0 Merchandised Transmission Automatic Provisions, O/D
M32 Transmission, Auto 4 SPD, HMD, 4L60-E, Electronic, HD
NK4 Steering Wheel Sport Leather
NP7 Steering Column EEC Approved
NT4 Emission System EEC 05
QG6 Wheel 18 x 8.5 Front and 19 x 10 Rear, Aluminum, Styled
T62 Lamp System Daytime Running - Delete
T79 Lamp Fog, Rear
T84 Headlamps Right Rule of the Road, E Mark
T90 Lamp Signaling and Marker, Export
T93 Lamp Tail and Stop, Special
UA2 Theft Deterrent System Export Specific
UH3 Indicator-Low Tire Pressure , VAR 2
UL2 Frequencies European Radio
US3 Antenna Diversity
UV6 Display Head Up
U19 Speedometer Instrument, Kilometer and Miles, Kilometer Odometer
U3U Radio AM/FM Stereo, Seek/Scan, DVD, CD, Clock ETR, Navigation, Voice Rec , MP3
U52 Cluster Instrument, Electronic
U65 Speaker System 7, Premium
VC5 Label Shipping, Except US, US Possessions, or Japan
VG1 PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT CLEAR UNDERHOOD CORROSION PREVENTIVE(VG1)
VG9 PROTECTOR WAX,EXT BODY(EXPORT) PROTECTIVE BODY WAX(VG9)
VH5 Plate Vehicle Identification
VJ4 LABEL, EXPORT CHILD SEAT LOCATION LABEL CHILD SEAT LOCATION(VJ4)(EXPORT)
VL4 License Plate Front Mounting Package, EEC
V76 Hook Tow
V78 Vehicle Statement-Delete
XL7 Frequencies Rating 315 MHZ, Long Distance
XL8 Frequencies Rating 433 MHZ
XGN Tire Front-P245/40ZR18-88Y BW HW4 HI-Performance
YGJ Tire Rear-P285/35ZR19-90Y BW HW4 HI-Performance
Z51 Performance Package Handling
1SA "Option Package Includes above 1SX plus:
Side Air Bags, Custom Sport Adjustable Seats, Power Passenger Seat, Electrochromic Rear View, drivers side mirrors, Air Filtration - includes pollen filter"
19I Interior Trim Ebony (I) (00)
193 Trim Combination Leather, Ebony (3) (00)
CT1 Country Belgium
EXP Export I.E.S
T79 Lamp Fog, Rear
UV6 Display Head Up
V76 Hook Tow
Stef84- Blown
» Corvette
CORVETTE C5 à vendre chez Auto Salon Singen
» (RE) Présentation et tout le toutim -pas taper, pas de Corvette.. si si Corvette NOW!
» Bonjour à tous
» Corvette ZHZ
» ZIP, CORVETTE CENTRALE, ECKLERS, CORVETTE AMERICA, ETC ETC..
» Bonjour à tous
» Corvette ZHZ
