Les messages de l'ODB
Hello,
je me demandais si il existait la liste des messages que peut afficher l'ODB.
Du style le célèbre "Echauf stabilité " ou un truc du style, ...
Avec la signification en clair
Thanks
Thanks
DreamCorvette- Turbocharged
- Nombre de messages : 1701
Modele Vette : ex C5 2003 Galaxy Silver
Re: Les messages de l'ODB
It's in English my friend, sorry, but easy to translate
ABS ACTIVE
ACT HNDLG-WARMING UP
ACTIVE HANDLING
BRAKE BEFORE SHIFT
CHANGE OIL NOW
CHANGE OIL SOON
CHARGE SYSTEM FAULT
COMPETITIVE DRIVING
COOLANT OVER TEMP
CRUISE DISENGAGED
CRUISE SET XX KM/H (XX MPH)
DOOR AJAR
ENGINE PROTECTION, REDUCE ENGINE RPM
FLAT TIRE-XX, MAX SPD 55, REDUCED HNDLG
HATCH AJAR
HIGH OIL TEMPERATURE, REDUCE ENGINE RPM
HIGH TIRE PRESSURE-XX
HIGH TRANS TEMP
HIGH VOLTAGE
LOW BRAKE FLUID
LOW FUEL
LOW OIL LEVEL
LOW OIL PRESSURE
LOW TIRE PRESSURE-XX
LOW VOLTAGE
LOW WASHER FLUID
MAXIMUM SPEED 129 KM/H (80 MPH)
OVER SPEED WARNING
PULL KEY-WAIT 10 SEC
REDUCED ENGINE POWER
RESERVE FUEL
SERVICE ABS
SERVICE ACTIVE HNDLG
SERVICE COLUMN LOCK
SERVICE RIDE CONTROL
SERVICE TIRE MONITOR
SERVICE TRACTION SYSTEM
SERVICE VEHICLE SOON
SHOCKS INOPERATIVE
TONNEAU AJAR
TRAC/ACT HNDLG-ON/OFF
TRACTION SYS ACTIVE
TRUNK AJAR
UPSHIFT NOW!
WARM UP COMPLETE
ABS ACTIVE
ACTIVE HANDLING
BRAKE BEFORE SHIFT
CHANGE OIL NOW
CHANGE OIL SOON
CHARGE SYSTEM FAULT
COMPETITIVE DRIVING
COOLANT OVER TEMP
CRUISE DISENGAGED
DOOR AJAR
HATCH AJAR
HIGH TRANS TEMP
HIGH VOLTAGE
LOW BRAKE FLUID
LOW FUEL
LOW OIL LEVEL
LOW OIL PRESSURE
LOW VOLTAGE
LOW WASHER FLUID
OVER SPEED WARNING
RESERVE FUEL
SERVICE ABS
SERVICE COLUMN LOCK
SHOCKS INOPERATIVE
TONNEAU AJAR
TRACTION SYS ACTIVE
TRUNK AJAR
UPSHIFT NOW!
WARM UP COMPLETE
Mimi77- Coup de Cœur C.P.
- Nombre de messages : 5356
Many thanks !
tiens , OVER SPEED WARNING fonctionne pas sur la mienne , heureusement !!
Ce n'est pas l'ODB mais l'OBD (On Board Diagnostic).
- Nombre de messages : 5747
C'est pour les versions pays du GolfeAlec a écrit: tiens , OVER SPEED WARNING fonctionne pas sur la mienne , heureusement !!
WHIZZ- Coup de Cœur C.P.
- Nombre de messages : 12825
» boites des messages
» Messages d'alertes
» MESSAGES D'ALERTE
» Bonjour à tous
» Amortisseurs,messages et voyants
» MESSAGES D'ALERTE
» Bonjour à tous
