Récupération codes RPO pour VIN
Bonjour à tous
Est ce Uelqu'un pourrait me récupérer le détails des codes RPO pour le VIN 1G1YY22G915124928?
Merci d'avance!
Denis
Merci d'avance!
Denis
Denden06- Long Block
- Nombre de messages : 122
Modele Vette : C5 2001 Navy Blue, capot Tiger Shark
Re: Récupération codes RPO pour VIN
Tu peux le faire directement sur http://www.compnine.com/vid.php
Résultat :
RPO Description
UL0 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,AUTO TONE(UL0)
UL2 RADIO FREQUENCY(EUROPEAN) EUROPEAN RDO FREQ(UL2)
UV6 DISPLAY,HEADUP HEAD UP DISPLAY(UV6)
UV7 ANTENNA, RR WINDOW, RADIO ANTENNA,RR WDO(UV7)
UZ6 SPEAKER SYSTEM 6, QUAD FRT DR MTD, DUAL QTR MTD 6 SPEAKER SYSTEM(UZ6)
U1S PLAYER MULTIPLE COMPACT DISC MULTIPLE CD PLYR(U1S)
U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR KPH SPEEDO(U19)
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL USED OUTSIDE U.S. AND JAPAN(VC5)
VD1 PROVISION OPTIONS,EUROPE(EXPORT) EUROPEAN PROVISIONS(VD1)
VG1 PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT CLEAR UNDERHOOD CORROSION PREVENTIVE(VG1)
VG9 PROTECTOR WAX,EXT BODY(EXPORT) PROTECTIVE BODY WAX(VG9)
VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT) VEH ID PLT(VH5)
VJ4 LABEL, EXPORT CHILD SEAT LOCATION LABEL CHILD SEAT LOCATION(VJ4)(EXPORT)
VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC FRT LIC PLT MTG PKG FOR EEC(VL4)
V76 HOOK,FRONT TOW FRT TOW HOOK(V76)
HOOK,FRONT TOW(EXPORT) FRT TOW HOOK(V76)
V78 VEHICLE STATEMENT(DELETE)(EXPORT) V78)
XGG TIRE FRONT P245/45ZR17 BW TL SBR HW4 EMT TIRE(XGG)
YGH TIRE REAR P275/40ZR18 BW TL HW4 SBR EMT TIRE(YGH)
Z51 PERFORMANCE HANDLING PACKAGE PERF HDLG PKG(Z51)
PERFORMANCE HANDLING PACKAGE PERFORMANCE HANDLING PKG(Z51)
1SB PACKAGE-OPTION 02 (1SB)
28U EXTERIOR COLOR,PRIMARY (28U)
EXTERIOR COLOR,PRIMARY,BLACK SAPPHIRE METALLIC (28U)
EXTERIOR COLOR,PRIMARY,DK CLOISONNE BLUE MET (28U)
EXTERIOR COLOR,PRIMARY,NAVY BLUE MET (28U)
67I INTERIOR TRIM,CAMEL (67I)
673 TRIM COMBINATION- LEATHER, OAK (673)
AAB MEMORY DRIVER CONVENIENCE PACKAGE CONVENIENCE PKG(AAB)
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) MAN RST SYS(AX4)
BAG PARTS PKG EXPORT PARTS PKG(BAG)
BGR PLANT CODE - BOWLING GREEN, KY, USA
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B4H MODIFICATION-NOISE CONTROL, EXPORT MODIFICATION-NOISE CONTROL(B4H)(EXPORT)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
CF7 ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7)
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
CT1 COUNTRY,BELGIUM(EXPORT) BELGIUM(CT1)
DD0 MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
EXP EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP)
FE3 SUSPENSION SYSTEM,SPORT SPORT SUSP(FE3)
G90 AXLE REAR 3.15 RATIO 3.15R(G90)
G92 AXLE,REAR,PERFORMANCE RATIO(MERCHANDISING OPTION) PERFORMANCE R/AXL RATIO(G92)
IL3 TRIM,INTERIOR DESIGN (IL3)
JL4 CONTROL ACTIVE BRAKE ACTIVE BRAKE CONTROL(JL4)
JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
K63 GENERATOR 110 AMP 110 AMP GEN(K63)
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
MAE MARKETING AREA EUROPE(EXPORT) EUROPE(MAE)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4)
NP7 STEERING COLUMN(EXPORT) STRG COL(NP7)(EXPORT)
NT3 EMISSION SYSTEM EEC 00 EEC 00 EMIS SYS(NT3)
QG1 WHEEL 17 X 8.5, FRT & 18 X 9.5 RR, ALUM, PAINTED ALUM WHL(QG1)
T62 LIGHTING DAYTIME RUNNING ----DELETE T62)
T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
T84 HEADLAMPS,RH RULE OF THE ROAD,(MARKED E) RH RULE OF ROAD HDLP(T84)
T89 LAMP,TAIL AND STOP(EXPORT) TAIL & S/LP(T89)
T90 LAMP,SIGNALING AND MARKER(EXPORT) SIG & MKR LP(T90)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
Résultat :
RPO Description
DreamCorvette- Turbocharged
- Nombre de messages : 1701
Modele Vette : ex C5 2003 Galaxy Silver
Merci!
Donc il s'agit d'un modèle Europe de 2001 vendu en belgique à l'origine d'après ce que je vois.
Le vendeur indique que la date de première mise en circulation est juin 2005...ça me parait très bizarre qu'un modèle de 2001 n'ait été immatriculé pour la première fois qu'en 2005....il faut que je vois le carnet d'entretien, ça devrait fixer les idées .
Merci encore
Denis
Merci encore
Denis
Quasi toutes les Corvette en Europe ont le code CT1 Belgium, mais ça ne veut pas dire qu'elle ait été immatriculée en Belgique la 1ere fois.
Et c'est arrivé aussi que des modèles européens aient été immat la 1ere fois plusieurs années après la date de fabrication. On a quelques exemples sur le forum.
WHIZZ- Coup de Cœur C.P.
- Nombre de messages : 12825
WHIZZHOT a écrit:Quasi toutes les Corvette en Europe ont le code CT1 Belgium, mais ça ne veut pas dire qu'elle ait été immatriculée en Belgique la 1ere fois.
Ok, mais quand même, 4 ans entre la fabrication et la première mise en circulation...et pour le coup je me tape une CG plein pot alors qu'elle devrait être moitié prix...et comme c'est un vendeur de VO, je me méfie sérieusement, ces types la te vendent des voitures comme des tapis persans ou des frigos
J'attends les détails du carnet d'entretien, si c'est clean, j'irai la voir dans 2 semaines à mon retour de déplacement.
...Il faut faire une réclamation au 1er acheteur en lui demandant pourquoi il a tardé à l'acheter car toi maintenant... etc etc
Elle est venue à la nage
Oui, méfiance ...
Oui, méfiance ...
bonjour à tous!
quelqu'un pour me donner les codes de ma C6?
VIN 1G1YY26W685131945?
Merci d'avance!!!
Merci d'avance!!!
patrice78620- En kit
- Nombre de messages : 29
Modele Vette : C6 competition
Voilà : https://i.servimg.com/u/f57/17/68/67/06/1g1yy212.png
merci !!!!!!!
bonne journée!
bonne journée!
» recupération de code erreur
» Récupération d'un brouillon
» codes erreurs
» codes erreurs.!!!
» Codes...
» codes erreurs
» codes erreurs.!!!
» Codes...
